Clutch Slave Cylinder Pushrod
Timberrick
New forum user
After 30 years in boxes..the Tiger is getting back together but...clutch slave cylinder pushrod is missing. Does anyone have a spare? or an accurate drawing so I can have one made?IT was a bad part to misplace!
If you still have the end bit that goes into the clutch rod, simply use a bolt with one end ground into a ball to fit the cylinder piston
If not then I see repos on FleaBay from time to time
Now I have lost mine, and no reproductions on Fleabay!!
SS do not have any, so before I go and make some, are there reproductions available?
If I do make some, I may drill a safety wire hole in the bottom of the spring clip groove, to have the ability to dispense with the clip and wire the ball end to the clutch arm - comments?
Bryan
I have a lot of pushrods- original and repo ones that are pretty good-
Spares
Nice to have a spare along with the clip.
My first car had a "There I fixed it, bolt ground down."
Certainly a no see um fix unless it's on a lift. I'm a little hard pressed to figure how it can drop out and fall off with the clip on and a hydraulic failure.
I've lost way bigger pieces. Since Tim M. quit making them maybe making some makes sense. Unless Bryan has a big pile of them.
Bryan
steve- total length is 3.36 long -treads are 1.20 long -hope that helps-note the notch is not filed but pressed to .200( for strength)
Here's a spare I have for the E-kit.
