With adjustable shocks, they run about $450 for shocks/springs from Jegs/Summit ... $50 less with NON adjustable shocks... To put that in perspective, the 'club' Edelbrock shocks are $375/4 and Dales springs are $200 a pair...
I used MS301-08375 ... for reference, the shocks are 7 5/8" compressed and 11 " extended . I ended up building a new lower mount that was stronger and it also mounted the shock 1/2" lower... that necessitated extending the shock length. I did that because I had some fears of coil bind at full compression but I suspect I could have just bolted them in without those mods..especially as I ended up cutting the top rubber donut in half for more lowering. I've even heard of guys running NO top donut...
I think the car rides great!!
When I bought it, the P.O. had hacked ( literally!) 2" off the top of the stock springs to lower the car and then realized it was too much and had added 2 aluminum coil spacers ( each side!) wound in between the coils ... let's just say the ride was 'harsh'!
B382000446
