The bearing (balls) are found at any good hardware store. The felts I use are the common battery terminal protectors . It's those darned bicycle races that can't be found anywhere ???Read a couple of post concerning the steering column mention of Rick Moran, I've been unable to find this name in the cat membership roster, I'm still looking for bearings and races and felt... Any current information would be helpful.Thanks 🐯
rick has bearing and felts- last I bough
Thanks for your reply I will see if I can get them from s&s the races I mean 🙂🐯The bearing (balls) are found at any good hardware store. The felts I use are the common battery terminal protectors . It's those darned bicycle races that can't be found anywhere ???
