Dana 44 rebuild
I am a very happy chap at the moment. The rebuild of my Tiger is progressing. We have finally rebuilt the toploader with the low first gear and the wide ratio gears, The next project is the dana rear end. I had previously built a axle remover that worked very well. Finally had to remove the dana gears so the new gearset and lsd can be fitted. Checked google and showed one guy using chains and a slide hammer to remove the crown wheel unit. Checked another site that said using a ball of rag jammed between the crown & pinion and then turn the pinion worked. Yes, one ball of cloth, turned the pinion and the gearset popped out.:D:D:D
