I have tore down the calipers, cleaned/painted, and am now ready to install the SS SS pistons. I have tried to push the pistons in with the new rubber and am having no luck. The bores are good and I have taken out the bleeder screw and the hose to make that there is no pressure build up to keep them from going in.. How much pressure/strength to put the pistons in or is there a trick to it. I have lubricated the rubber with brake fluid.
Thanks,
Thanks,
