Duke's 66 Tiger videos.
Duke Mk1a
I have had fun making videos for a couple of years now. I will link them all here and add to this thread as I make more.
My German father-in-law in my Tiger when 260 powered (May 2010)
http://youtu.be/xRMrg0Q33tg
A walk around my garage as I build the 347 (Mar 2011)
http://youtu.be/TqSC9ZLMHw8
The freshly built 347 on a engine dyno (Apr 2011)
http://youtu.be/gBUFgMc-HvQ
A short clip of the Tigers exhaust sound (May 2011)
http://youtu.be/z4Ejcr7-byU
A inside car view of running through the gears with the new engine (Jul 2011)
http://youtu.be/suEoGJJ5faA
My first drag race with the 347, smoked a supercharged Mustang (Oct 2011)
http://youtu.be/5uW8p-7Pkr8
My fastest 1/4 to date, inside car view (Nov 2011)
http://youtu.be/ge3vJb06bDo
Wide Band Oxygen sensor installed (Apr 2012)
http://youtu.be/86erf8z_cKY
Having fun with some old slicks and the newly installed front brake line-lock. (Jun 2012)
http://youtu.be/liZy3H7A2Xk
1st Chassis dyno run with the new engine, 454 crank HP (386 RWHP) (June 2012)
http://youtu.be/eSyK4m7smyQ
venice532
drag racing video
Hi Duke, thanks for posting those.
Are the last two videos (tire burning and dyno) the only two that are taken after you figured out that the oil ring was bent over and causing problems?
If so then it's amazing your fastest drag race time was just over 12 seconds despite the ring issue.
Bob J.
Duke Mk1a
Thanks guys,
Yes those two are after the fix. I look forward to getting to the track again as I have a Holley Ultra HP 650 feeding the engine now too. I have been on a late model Mustang forum for info on my 347. The Fox bodies Mustangs are running mid to low 11's with as much or less HP than I have and 700 lbs. more of car. I should be in the 11's for sure once I have the balls to launch at 6000 rpm with drag slicks.
VaCat33
Duke
Always enjoy watching your Tiger perform.
I still think you need to make some "How To" videos for us less talented.
Duke Mk1a
What do you want to know "How To"? I have always said, that I do nothing new with my car. If I am blazing a new trail, I am wrong as it has all been done over the past 46 years.
VaCat33
Auto Mechanics 101
Duke
Nothing in particular...Just a bit of self-deprecating humor on my part. I can use help on just about any project I undertake, including routine maintenance of my Tiger.
I have all the manuals, shop notes etc but I still get a lot of help from the guys on this forum, who often walk me through things by the numbers. Your videos just reminded me of the old saying that a "picture (video) is worth a thousand words."
