I recently encounter an issue with engine oil collecting/dripping down from the lowest point of the bellhousing. In the beginning I suspected a rear main seal leak, but when carefully examining it looks as if it is running down the the block on the passenger side. Suspected the passenger valve cover leaking and re- sealed it, but then found as small lake of oil on rear top of the block. Looks to me as if the rear inlet manifold cork seal is gone. Any advises ?
Furthermore it seams that also the oil pan on the rear starts to leak - oil running down the clutch shield. Since I'm anyway about to exchange the oil pan any experiences with these single piece rubber oil seals ? There are several makes available. Any recommendations or don't do's?
