I can't say that the coilovers work 'better' .. but I wanted the ability to adjust the ride height and the QA1's gave me that...what I took out was stock coils that had been chopped 2" ( apparently too much) and then had aluminum coil spacers between the coils... rode like cr@p and I didn't want to buy 3 sets of springs to get things right... and I like 'tinkering'
Dale's kit has mixed reviews... it's a lot quicker... ( same rack as my wife's Sprite) which makes parking a b#itch but I've heard people say they 'think' the ackerman is better using that setup with the MGB arms... Mayfs numbers don't agree though.
Table 1
Ackerman Turn Angles
Inside Wheel Input Outside Wheel Output
Degrees Perfect Tiger MGB Special
1.00 0.99 1.00 1.00 1.00
2.00 1.96 2.02 2.01 2.01
3.00 2.92 3.04 3.02 3.03
4.00 3.86 4.07 4.04 4.05
5.00 4.78 5.11 5.06 5.07
6.00 5.69 6.16 6.09 6.11
7.00 6.58 7.22 7.12 7.15
8.00 7.46 8.30 8.15 8.19
9.00 8.32 9.38 9.20 9.25
10.00 9.17 10.47 10.24 10.31
11.00 10.01 11.58 11.30 11.37
12.00 10.83 12.69 12.36 12.45
13.00 11.64 13.82 13.43 13.53
14.00 12.44 14.97 14.50 14.63
15.00 13.22 16.12 15.58 15.73
16.00 14.00 17.30 16.67 16.84
17.00 14.77 18.49 17.77 17.96
18.00 15.52 19.70 18.88 19.10
19.00 16.27 20.92 19.99 20.24
20.00 17.00 22.17 21.12 21.40
21.00 17.73 23.44 22.26 22.57
22.00 18.44 24.73 23.41 23.76
23.00 19.15 26.05 24.57 24.96
24.00 19.85 27.40 25.74 26.18
25.00 20.55 28.78 26.93 27.42
26.00 21.23 30.20 28.14 28.68
27.00 21.91 31.65 29.36 29.96
28.00 22.59 33.15 30.60 31.26
29.00 23.25 34.71 31.87 32.60
30.00 23.91 36.32 33.15 33.96
I haven't checked my setup thoroughly, but I know from some early measurements that with the inside wheel @ 20°, I get just over 17° on the outside which is just about perfect...at full lock the overall length from steering arm to steering arm gains about 1" . I had Lou Anderson's original drawings and mocked up his setup but it appeared to have terrible 'bump' steer so I found that mounting the heim pivot directly to the crossmember instead of the lower A-arm cured most of that... I also used MGB steering arms so the turning circle isn't reduced quite as much as his setup
I put in the power steering partly because my rack need rebuilding.. also my car had 245/50's (not any more) on the front which made it a bear to steer... and also I knew it had been done before so was at least possible although I think my installation is quite unique .
The crossmember brace idea came from a couple 'hot rodders' that were over for beers and I was saying how the car has issues with the crossmember wanting to cave... they said that maybe a 'monte carlo' style bar tying the two tops together would work... I actually had one fitted across running in front of the block and behind the water pump but in the end decided to brace each side directly which I think is a very simple/strong fix.
B382000446
