To help avoid percolation problems this summer we just installed a Holley heat shield under the carb. It took a little trimming.
I recorded bowl and water temps before I installed it and after. Here’s what I got:
At 200+ the no shield bowl temp was 167 versus 104 with the shield
at 240, no shield 176 versus 159 with the shield
at 250, without the shield the fuel boiled and the engine stopped with the bowl showing 194.
at 250 with the shield the bowl temp was 171.
The shield certainly seems to be doing a good job.
The Holley pn is 108-70. About $36 from Summit.
I had to use longer studs since it comes with a fat (5/16”?) insulating gasket. (actually used regular bolts for now.)
Buck
Buck
