Fair enough: randy willett, P.O. Box 581, Meredith, NH 03253I probably have one... if you'd give me back mine and a couple of copies.... that'd work for me
I'll box it up and send it off in the morning!Fair enough: randy willett, P.O. Box 581, Meredith, NH 03253
YUP, the E Mails are coming in already.Randy, I will buy one of the repros when you are done.
You raided the local hardware store for rubber doorstops for the buffer on it?YUP, the E Mails are coming in already.
Nope; much easier to upsize the welded nut and use a bonnet buffer rubber.You raided the local hardware store for rubber doorstops for the buffer on it?
I'd just use a riv-nut at the original 10-32 size... I have hundreds. the rubber bungs are easy to come byNope; much easier to upsize the welded nut and use a bonnet buffer rubber.
You'll be covered.I'd just use a riv-nut at the original 10-32 size... I have hundreds. the rubber bungs are easy to come by
no good deed goes un-punished.... Randy, please send it back... I'm only out the $10+ to waste my time.
