Wanted headlight ring
I'm looking for a headlight body ring for a 67 mk1a
The inner fender support ring that the bucket mounts to is available thru places like Brit Motor Heritage or even Moss. I have a couple here if the search gets complicated.
I was yakking about the Headlight Bucket mounting ring that fits just inside the fender aperture.
lee
I don't think I used the correct words.Not sure what it is called. Bezel? I need the headlight body ring for a mk1a.
pfreen
Can you show what you are looking for from a diagram? I have no idea what a headlight body ring is.
I'm guessing you are talking about the actual headlight rim. The eyelid that goes over the headlight on the body?
lee
correct headlight rim that is what I need. Thank you!!
clip-on or screw-on??
If it's for a MK 1A then it should be the screw on style unless the bucket has been changed to one using the clip on style. It would be the same as a series 5 Alpine. The clip on style can be drilled to use the screw if fitted. I've seen that done several times.
sadiq
Sorry Bryan I have been travelling please DM me will send you the payment
