cadreamn67
Platinum Forum Member
Any of you guys have this cam and motor and had it dyno'd? I would be interested in what other mods you made with it and the dyno results. Specifically, did you have to notch pistons for valve clearance? Lift seems to be higher than the lift for the solid lifter cam LAT option described in Performance Tuning the Tiger. Also, how loud is the lifter ticking when properly set up? (I think I have a bad lifter in my 260 and it is a bit worrisome. Not sure what 16 tickers would sound like, maybe more harmonious?!)
Cheers, Gene
Cheers, Gene
