One of the simpler air flow corrections we do is the replacement of the flat air dam at the bottom of the radiator cowl with a piece of 1/2" steel pipe. In use, the pipe allows free flow of air around it which keeps going rearward. The flat original cowl's bottom, creates low pressure vacuum at the lower front of the rad and actually pulls hot engine compartment air back thru the rad. Fairly simple body welding project and it works.Cool! Thanks
