I was wondering what those more experienced in rebuilding Girling master cylinders than me have done. I have rebuilt both masters and the slave cylinders (as well as rear wheel cylinders) and one of the last steps on the Girling instructions was "pack the dust cover with the red rubber grease ) . However, I noticed that there is either a drain hole or a vent hole in the rubber boot/dust cover and it seems that with packing it with grease would block the small hole. Here are instructions which indicate that the rubber grease is only put around the edge and the hole be kept clear and facing down to drain any moisture: https://www.pegasusautoracing.com/pdfs/GirlingMasterCylinderRebuilding.pdf
Looking forward to hearing how this is handled.
