Master cylinder
bleedfordblue
I have heard that a 1980 subaru 1.6 duel master cylinder will work as a replacement over the stock Tiger master. Has anyone had experience with this? If so what did you have to do to make it work?
Ford Courier for a dual m/c, Subaru as well. I think the Subie looks the best. Use the search window for either will yield a ton of threads and at least a quarter ton of opinions. I have a single Wilwood it's cheap and looks more the part, but a little firm on pedal.
If you are mobile device entering the search terms I always have to cut n paste from another app to add text in the search bar even with Android 10.
Like to know ?
I was having trouble finding the Subaru unit some time ago (out of stock & not expected). Let us know if you find a source. THX
Jon B
I have a Subaru master that came with my car, it bolts right up and I had Tom Hall convert the pedal to a 6:1 ratio since I can't run a booster. I ran new lines and switched to a pedal-activated brake light switch.
-Jon
Maliburevue
Raybestos MC39418
Parts Geek has only one in stock - $130.27
TH Motorsport has only one in stock - $156.08
Amazon has at least one in stock - $194.10
Gosh, do I have to do everything for you people?!!! Hahahaha!
steven
They work well for LHD Tigers, our RHD Tigers, the front reservoir fouls the carby linkage. still have not found one
