MK II Rear Dimensions
Better late than . . . . . . . . A while ago, I rcvd an E-mail from one of the faithful asking about the panhard mount dimensions on a MK II rear, and the frame bracket location. A hard drive glitch lost the E-mail, so here are some photos for all to spread around. The "clocking" of the mount welded to the rear is the same as a MK 1/1A (2 O'clock) and the distance from the bracket's panhard hole to the inside of backing plate remains 11-1/4" ish. Another photo shows our version of the frame mounts location and bracket. Any good welder can relocate the bracket arm on the rear.
Yes, the rear end in gray epoxy primer is an original MK II from the barnz. If the party could E-mail me once more, I could follow thru with more detailed measuements if needed. thx
