What started out as an 'that should be easy' project has not. Any hints, install suggestions to get a new soft top to windshield rubber (SS) into that tiny little track ..
Vaseline helps. A # 4 trim screw at your starting point keeps it in place while you begin tucking the miserable critter. Factory production must have had a trick or two.I believe it's pretty similar to the door seals. If so, those plastic tools for popping apart interior and upholstery parts work pretty well and won't scratch the paint. It can be tough to get started but once you do, you should develop a technique and hit your stride.
