Oil filters
Tiger tamer
I have been looking at different options on filter set ups.
I allready have the 90deg adapter, so if I could use it, it would be good.
The trouble is all the filters are about 3.6" in dia and won't quite fit.
I found these on summits web site, but they don't have an anti drain back valve. With the filter needing to be horizontal I would think it would need one.
I presume the anti drain back valve sops the filter from emptying if not verticle and the fitting surface at the top.
The K&N is very expensive as well.
Any help appreciated.
http://www.summitracing.com/parts/pfs-10881/overview/make/ford
http://www.summitracing.com/parts/sof-209-561b
http://www.summitracing.com/parts/knn-ss-2004
http://www.knfilters.com/oilfilter.htm
chirodoc
With the 90 degree adapter ( OLD FORD ECONOLINE) if you rotate it about 270 degrees and use a FORD CAPRI V-6 filter, works GREAT. REFERENCE CAT SHOP NOTES. When changing the filter pop A hole on the bottom to drain. EASY!
Tiger tamer
The capri filter comes up as the same part# as the windsor. The 90deg adapter is a Ford motorsport part. Perhaps it's different than the econoline ?.
tomNjo
Does that mean a WIX 51515 should work? It's listed as the oil filter for the V6 Capri.
chirodoc
OIL FILTERS
MOTOCRAFT FL 400, FRAM PH 3600. PUROLATOR 20064. BOSCH 3422 ARE ALL THE SMALLER DIAMETER. APPLICATION FOR A TAURUS
Tiger tamer
Problem solved.
Thanks chirodoc.
The K&N Ph 2009 has the by pass and anti drain back as well.
Cheers Mal
FDubIrl
I'm hoping to replicate your solution Tamer!
See attached the current setup on my target vehicle. I feel fairly confident the adapter will fit in place the current filter (which is only a 2"). The adapter I think is a total of 2.4" but that's at it's centre point so I think it will likely clear the header.
Thanks for the PM exchange! As you can see I am now "live" on the forum!
