Hello all,
After completion of the LAT 9 center cap project. I have enough interest in doing a Panasport insert of the LAT 9 Tigers head. It will be CNC machined out of aluminum and should be about 3/16" thick and 2" in diameter. I plan to remove the plastic Panasport emblem and glue/epoxy the insert to the cap. The cost will be $23 ea and shipping should be $7.50 for 1 or 20. Contact me off list if you want to order some. I will need a minimum of 30 to have the machinist make the run.
I have not had any complaints on the LAT 9 caps workmanship so the quality is not an issue. The picture is of the LAT 9 cap but the Tigers head will be near the same size in proportion.
Dave Green
alpdavegre@msn.com
Dave Green
alpdavegre@msn.com
