Hello,
Thanks for the info about the availability of a modern limited-slip / Posi. units. Now, I am looking for opinions on best gear ratios between the tranny & rear. Bill Martin’s TKO-600 kit will be available in either a .64 or .82 fifth gear option along with a 2:87 first gear ratio, so I am wondering which rear end gear would be ideal for 90% street-driven car. Depending on which rear ratio I use with the LS / Posi, impacts which ratio fifth gear ratio I order.
Even though modern computer controlled fuel injected cars can drop the rpms down to 1500 on the highway, some say that our old carb-equipped motors can not operate below say 2500 rpm or so efficiently. The motor is a 274hp / 310 lbs, original 289. The Dyno spec sheet I have started at 3K rpm (nothing noted below) & it was already at 290 ft lbs. of torque. I want to retain the original LAT 13” wheels & with the 60-series tires have an overall diameter of about 22”. Using one of those RPM calculators available on the Net, I came up with the following RPMs at 70 mph for these two combos. With a stock 2:88 rear & the .82 fifth it should run at 2525 rpm at 70 mph. A set of 3:31 gears with a .64 fifth should be about 2265 rpm at 70 mph. Either one appears to me to be somewhere near a decent rpm combo.
What do most street-driven Tiger owners run, the stock 2:88s? Would 3:31 gears be too much with those little 22” tires & the 2:87 first gear of the TKO-600 tranny? Would first gear with that combo not make it through the intersection? Just curious what combos others have had luck with. Thanks….
