texastigert
Quick question, didn't I read somewhere, here on the forum, where someone just added an extra leaf spring (from an Alpine) to the Tiger rear spring setup? making a stiffer ride? Thanks, Tim
Not sure how to answer that one, to be honest. I've never measured either a stock Tiger or my car to see how much droop there is under static load, i.e. how much the leaf bends when you put the rear end's weight on it. I'd guess using stock springs with the extra leaf would raise the static ride height a smidge, maybe? It definitely would give more rate, but whether that solves your problem, I wouldn't guess.
Are there options to create clearance for the caliper to allow the suspension to move without hitting? I'd rather keep rear compliance than try to keep the rear out of its travel to solve this one, personally
I know the question was on adding another spring to the rear but a better choice IMHO is the get a set of rear leafs from Dale.
Stiffer springs and anti axel tramp all in one.
10034
Rear Leaf Springs
190 PPI Torque Leaf
$475.00
I never heard of anyone wanting it stiffer in the rear of a Tiger
