I had an upside down oil filter adapter in the stock location that developed bad leaks in more than a few places so I decided to assemble a modern solution. As I was finishing up installation, I read the article that Tom Hall recently put out about relocating the oil filter to the left wheel well. If I had read the article first, I would probably have gone this route, but I wanted to try this first and develop it for people that don't have a stock filter arrangement, and/or do not want to cut holes in the inner fender well.
I sourced parts from British America Transfer in Sarasota (http://www.batinc.net). Their company was listed in an article of Classic Motorsports Magazine where they overhauled a blue Tiger.
The engine block adapter I went with was the same that Tom used - Canton Racing 22-595. I bought that part on Amazon for $82.
The -10 'lightweight racing hose' from BAT is pricey, but I'm thankful not to have to deal with prickly SS sheathing. The AN fittings are spendy too, but I wanted to make sure I wasn't getting Chinese quality. I used two 90º fittings and two 60º fittings. I also used three straight 1/2" NPT to AN fittings and one 45º piece. The adapter plate is made from 5" x 1/4" flat stock. I made some templates with google sketchup and was able to come up with some usable dimensions.
I'm very happy with the Canton adapter - after a number of heat cycles, there are still no leaks. The hose was really easy to work with. I cut it with an angle grinder and after assembling the hoses, I swabbed everything out with some 40 caliber patches.
The installation was fairly straight forward and I'm satisfied with the result. I like that the oil filter doesn't drain after engine shut-down and is no longer oil oil starved for a few additional seconds to allow the filter to fill up.
I hope this helps!
Cheers, -Kevin
I hope this helps!
Cheers, -Kevin
