3:48 AM Sunbeam Tiger work...
Finished the body filler on the front edge of the dash sheet metal. Had a lot of spot welds and wanted to cover them up since I'm not using a dash pad. Roughed it up with some coarse grit, acetone for the clean.
Following the direction on the Rage can with hardener seems to not be a good move. Had to do 3 batches, each less and less hardner before I got it done. It kicked off hard to spread in 2min or so. Can said 3 to 5. Sanding later!
