QC on springs can vary more than we might think. I've measured numerous sets of race springs that have had as much as 18% variance in actual rate. Hyperco and Swift are the two vendors that have consistently been best, fwiw.
My personal opinion on a no-compromise Tiger set up (using oem front suspension, including A-arm location) for autocross is pretty simple and is pretty standard for old A-arm cars with poor camber curve: lots of spring rate and lots of static camber. I think the motion ratio of the Tiger's front suspension is in the .5-.6 range, so using a simple calculation, the wheel rate of a 450# spring is in the 115-165# range. I think you could argue spring rates in the 1000# range might be indicated, to get wheel rate somewhat closer to corner weight, as a starting point. I've heard stories of racers "back in the day" running intentionally bound up front A-arm suspension and relying on the old, taller profile tires to provide spring rate to keep out of the suspension...don't know if that's true or not, though.
But, I also like to drive my Tiger on the road and not beat the crap out myself and my wife, so compromise is part of the deal. I'm currently running 450# front springs, but I cut them years ago...can't remember exactly how much and, as a result, I can't begin to figure out how much it upped rate. I also run a decent amount of camber, like -1.5 when autocrossing on street tires. I may go to 600# springs, but it isn't a priority, as I have a dedicated autocross car and want to keep the Tiger comfy.
Rear springs I'm starting to re-think. I've always believed that the rear end needed to, basically, follow along and compliance was key. So, rear spring rate in the 170-190# range seemed to make sense to me. But, I'm hearing from Buck that might be something to reconsider
One other thing: If you're going to bigger rates, I'd really suggest doing the Tom Hall mods to the front end. You'll be putting more load into the known failure points.
