Steering Wheel Nut / Column Thread Size
lockfish
I have damaged threads on my steering column where the steering wheel nut threads on (65 Tiger). It appears to be a 9/16" w/ very fine thread. Can anyone confirm the size so I can buy the correct tap and die? Thanks
mr55s
Steering wheel nut
One way you can find the thread pitch is to go to a machine shop or tool rental place and ask if you can borrow or rent a thread gauge and measure a portion of good threads you have on the shaft or if the nut isn’t too bad take it in with you and have the machine shop double check. They can either clean up the threads or you will know what the pitch is so you can get the particular tap or die. Barring that maybe someone on this site knows.......
Brian
Nuts & Threads
Rick has the nuts at S.S. You can ask if he knows the size ?
I just popped mine off (7/8" deep socket ) to have a look and it appears to be about 9/16" but it's definitely finer thread than my 9/16" UNF tap :eek:
lockfish
I counted the threads and it appears to by 9/16"-28. Probably hard to find that tap and die.
Thread Count ?
In San Diego at the moment and just a couple miles from Smitty's Sunbeam Palace. Will drop in for a confirmation of the thread count & size. I suspect Brit bicycle 26 tpi threading ?
lockfish
Problem Solved
I found a 9/16-28 tap and die set locally and both sets of threads are good again. Thanks to everyone for the suggestions.
Now, I need some help with tearing down, cleaning bearings and reassembly of the steering column. There is a 1997 article by Jim Leach on TEAE, but it would be nice if someone had a procedure with pictures.
Tiny balls
A couple of cautions: The small valve spring on the end of the shaft applying tension is a bit of a bear to compress and free the circlip. The circlip groove is very shallow and requires deep cleaning pre-assembly. Pre-soaking the end of the shaft may or may not assist in getting the bearing to move without separating and dropping the 21 balls on the floor (1/8" at hardware store). If the inner & outer bearing shells are not too crusty, they are reusable. Battery terminal pads make great grease protectors. It's a patience and careful movements process.
