The intake manifold is in a confined space with the engine installed. I have found a lot of attempts at fitting a new intake, or refitting the original results in massive oil leaks. This is usually because the rear cork gasket gets slid out of position when the intake is re-installed. Here's an easy solution to this problem!
Before refitting the intake manifold, install 5/16 studs in each corner (of the heads). I always recommend using a product like Permatex "ultra black" around the water port sections of the intake gaskets and a liberal application of the same product above AND below the cork gaskets at the front and back of the intake valley. The studs will hold the intake manifold gaskets in place and will allow the intake to be dropped vertically square, so that the cork gaskets do not slide out of position.
Once the intake manifold is in place, install the remaining intake manifold bolts loosely, and then remove the studs at the corners.. Install the remaining 4 intake manifold bolts and torque to spec! This will result in no oil leaks, or gasket movement.
