I can't get my telescopic steering wheel to telescope. I believe it's stuck in the fully retracted position and I'd really like to extend it for more room. The column was rebuild about 25 years ago and has not been used until now (don't ask why). The tension bar (with the nylon clip in the photo) moves freely and seems to bottom out on a spring so it won't completely fall into the column. I believe the sliding part is the inner splined column seen just in front of the horn ring, correct? Any idea on how to free this up other than pulling and disassembling the column? If I try to drive the column in or pull it out is that going to destroy the column? TIA.
Tom
B9473100
Tom
B9473100
