I'm catching up on posting projects, this is a replacement for the sheet metal Tiger gas pedal linkage.
This is made with 1.5" x .0175" aluminum angle, about 5 inches long. Besides the aluminum angle you will need 2 3/8" rod ends and related hardware. The thin adjusting nuts that often are used are helpful as well, and finally 3/8" split locking collar(s).
This bolts into the stock location, and depending on fit should not require any other changes.
The throttle arm can be reused or an aluminum one can be purchased from Speedway Motors for about 10 bucks and a small extension made that should replace the old one.
I don't have the step by step up on the website yet, but here is the diagram on how to make it all work.
Happy Motoring!
Sandy
Happy Motoring!
Sandy
