D
dgraway
Guest
Since it is to cold to do much outside here in Minnesota right now I thought I would try to figure out what the actual difference is in the 2 versions of ford top loader shifter levers and which would have been original to my tiger (B9472344).
As far as I can tell the shorter shift lever was first and then was changed to a longer lever somewhere around B9472000 or so. This info came from CAT Parts BON that I borrowed awhile back. I also searched the CAT forum and TEAE and didn't find any posts regarding this question. This makes me think I should look for a longer version of the shift lever use with my manual transmission.
Does anyone know what the actual length of each version of shift lever is? I am collecting parts to put my original manual transmission back into car, currently has an automatic tranny installed, and would prefer to use the correct shift lever.
Any pics, measurements, etc of each version would be appreciated.
Thanks,
Dan
Thanks,
Dan
