I need some collective wisdom from the group. As I've finished the mechanical refurbishing on my Tiger, I've been driving it around a bit. I had noticed before that the gearbox was a bit notchy on downshifting, but I figured some worn syncros. Upshifting was fine. Now, on two occasions, I've found myself stuck in one gear, unable to shift at all. I got it to a trusted shop and have ruled out a slave cylinder issue or clutch issue. Some tweaking on the shift linkage seemed to solve the issue the first time, but it has happened again. They looked and they think it's an issue inside the box. Evidently, everything with the linkage is lining up as it should.
Fluid in the box: Redline 75/90 NS
Clutch system has been flushed/bled.
Time for a rebuild? Other possibilities?
