Hi all,
Contained in the toploader shifter mechanism are 2 brass washers around 0.005" in thickness.
They sit under the sort of U shaped bracket on the side with the spring attached.
On my gearbox, one of these washers has worn to the point where is has cracked in several places and may break up.
I wondered if anyone else had had this problem and what they did to solve it.
The Toploaderheaven website do a shifter refurb kit which has a ridged washer in it that may be their replacement for them but they aren't answering e-mails or calls at the moment so I don't know if this is the case.
Any help that anyone can give will be much appreciated.
Thanks.
Thanks.
