The vacuum that controls distributor advance is not the same as manifold vacuum. It is venturi vacuum, unlike manifold vacuum it increases with RPMs. Air flow through the carburetor venturis draw a vacuum based upon air flow (a fundamental principle of how carburetors work). That is why the distributor advance vacuum port is located on the carburetor and not on the manifold. Many high-end electronic ignition systems control the advance electronically. If your ignition is not capable of this, you will have to do it all by mechanical means with the weights and springs inside the distributor.
