wheel studs
Thanks and I could press out a used one from a front hub, but was hoping for a new one
Dorman 641-1267 is a 7/16-20tpi X 1.75" wheel stud as original $1.75 ea at my local NAPA.. if you're running mags or 1/4" wheel spacers I'd recommend a 2" long stud which was used on the big Healey. Moss part 031.293 at $7.89 retail
IvaTiger
Specs for torque on the 7/16 is only 45 foot pounds by the original manual It may be a good idea to go to 2 inch long and put a jam nut on it along with the original ball lug nut.
Bugeye Sprites and Triumph Spitfires have 3/8-24 wheel studs!!!!!
pfreen
My Lotus has 3/8-24 wheel studs. No problem, but it only weighs 1350 poundsšŸ˜Š.
