Wilwood front brakes
ktwhite
This for those who have the Wilwood front disc brake kit. Dose the tire/wheel combo mount in the same position as to its location inside the fender where the stock location or does it make the tire/wheel stick out further or deeper inside the fender?
I can only answer for the earlier dales wilwood kit with 10.5" slotted discs. Wheel track was the same
as the rotor is mounted on the backside on the hub, the track is unaltered.
