Hello all,
Well the new Wilwood front brakes in combination of the rear RX7 brakes is amazing. Never have I had the braking confidence I do now in the Tiger. I can now stop as well as go!
With the larger front calipers it is taking more fluid volume to actuate them. I don't like the feel of the pedal with the OEM 7/8 master cylinder. I want the application of brakes to be at the top of the pedal, not half way down. I would like to go to a 1" bore Wilwood cylinder.
I am keeping the Lockheed booster for the time being.
So - who has experience installing the 1" MC? What issues if any and which one did you go with?
Here are the two candidates -
http://www.wilwood.com/MasterCylinders/MasterCylinderProd.aspx?itemno=260-3378
http://www.wilwood.com/MasterCylinders/MasterCylinderProd.aspx?itemno=260-10375
TIA!
TIA!
