IvaTiger
After a long time of battling with installing the windshield using the CAT club rubber seal and having NO luck in fastening the stainless trim and side pieces that screw on correctly, I found the problem to be the profile of the rubber was too thick and had to use a razor blade to remove a lot of rubber in order to get the pieces to fit correctly. The rubber that I removed was from the center of the molding so it was not visible from outside or inside of the car. I am not concerned about any possible leaks because it is a fine weather Arizona car
Anyone else have this problem with the CAT club windshield rubber ?
The finished project worked out just fine
