I recently installed a new w/s, windshield to frame seal and frame to body seal... The currently supplied body to frame seal is much "harder" rubber than the previous seal and I found it impossible to make fit properly. I dug out an older. but still new seal, and while it wasn't curved like the current offering it was much easier to install. The real problem I now have is with the w/s to frame seal. It is also a much harder rubber than the previous seal and is also thicker. If I install the mirror and visor mount, the rubber buffer on the mirror stem is 3/16" away from the glass. If I take the visor mount out, the rubber buffer touches the glass as designed. This doesn't make much sense as the visor mount is considerably thinner than 3/16". Everything fit correctly with the old seal, unfortunately it was damaged and couldn't be reused. All of the stainless is installed and fits like it should.
I have thought of a number of possible fixes including a shim under the rubber buffer, milling the visor bracket at an angle on the back side, or modifying the mirror base. I was wondering if anyone else (besides mr55's!!) has had a similar problem, and what their solution was.
