3/2025 more Tiger Alpine stuff
boss-tiger
Late model hardtop project, very good hardware, new SS rubber, no rust $1800 - everything but new rear glass and headliner
Dropped front spindles $800, clean, good condition
LAT Fan $150
Tiger LAT Tri-y exhaust manifolds and required engine mount EM/repo early 1980's, new condition $750
SBF Ford Econoline 90 deg oil filter block adapter, bolt, gasket $200
Stock tiger remote oil filter adapter, complete $275
Pair gas tanks, restored/inside coated - very nice condition $350
Talbot green dot side mirror $225
dash red/green/blue small lights - very good condition $75
Restored license plate lamps (both sizes) $100 each
good used conv. frame - $175
Bpost pr convertible top hinges $150 reconditioned/painted, all threads good
Alger conversion sheet metal : tunnel, front fender caps, exhaust cutouts, etc - make offer (this was from a rolled Tiger I parted out in the 80's)
Tiger Toploader 1-2, close ratio, recommend rebuilding , has been stored behind workbench since mid 80's $500
Tiger toploader 2-2, wide ratio conversion, fresh/full rebuild by David Kee, zero miles - excellent $1800
.. other .. pm best method to contact, will consider offers - let me know if I am too high (or low ) - thanks
Good Morning:
I might be interested in the following items you listed:
1. Stock tiger remote oil filter adapter, complete $275
2, Pair gas tanks, restored/inside coated - very nice condition $350
3. Tiger toploader 2-2, wide ratio conversion, fresh/full rebuild by David Kee, zero miles - excellent $1800
So, 2 questions; is the wide ratio conversion a complete gearset or just the w/r gears, last question, could you maybe send a couple pictures of each of the 3 items to view?
Just added, do you have 2 "A" post buffers you might part with?
Thanks,
