Auction Results JAL 001 Tiger
kenmat
Did anyone catch the results of the Worldwide Scottsdale auction of the JAL 001 Tiger today???
Went for 120k + buyer fees.
kenmat
So, that would be 120 plus 12% buyer fee which is $134K..The red car..the so called LAT car went for $57k...or $64K.
I wonder what the sellers fees are. The buyers fees brought the auction house $20K on these two cars.
On the LAT car the commentator hyping the car said " Shelby Engineering created all the LAT upgrades"
The red car should have done better.... JAL 1 went for a little more than I thought it would. I am a pal of the previous owner and knew the cars thoroughly.
kenmat
I too thought the red car should have done better with the 5-speed, quick ratio et al.. It was a thoughtful mix of mods and upgrades and cosmetically pleasing with the color combo and upholstery..Couldn't build it for $57K or $64K...
I restored the body and hardtop and painted both... the materials alone were around $7500... The labor almost twice that.... while the car was supplied to me stripped (dipped), there was quite a lot of repairs that were required. It had been on a rotisserie so long, the doors wouldn't fit. it had sections of both front fenders replaced and the hood wouldn't fit the hole... and the rear qtrs. were rotten on both sides behind the tires. It was a lot of work!
HRS121E
Is not the elephant in the room being overlooked?
I would not like to be in that room when the latest buyer of B9470047 LRXFE realises he does not possess the '1st Production Tiger'.
That accolade belongs to B9470011 - ROTA 1, completed on / around the 3rd June, weeks before #47 was. Bearing in mind the suffix LRXFE did not appear on VIN plates until B9470036.
Lovely that the car possesses the first body number - 550001; not 001JAL as the auction house hyped it, but that is all that may be claimed. The auction patter from the rostrum kept trying to avoid saying '1st production Tiger' (as per its sales material) but it kept bursting out! Amazing to me too, how parts of the classics media swallowed WWA's spiel without question..
I met with the long term owner in England several years ago and we covered this then. However, without hesitation or doubt he sold on a truly excellent example of the marque.
yes, that is true, but... there is no way to deny that JAL 550001 isn;' the first production BODY.. It got held back for whatever reason and was assigned 9470047 for a chassis number.. So it wasn't finished when it should have been. None of that changes the fact that it is the first Pressed Steel shell.
BillRo
I bet there were issues with that first body and had to be corrected prior to introduction to the production line; the other early bodies went to early cars.
Bryan
it is what it is- the first Body car was loaded I guess first in the simi or lorie to have all the other parts installed -first in last out-
HRS121E
The first 5 Tigers: B947011 to B9470015 have Carnival Red paint. Moonstone followed, which is the paint on B9470047 LRXFE.
Having bodyshell No 1 is a fine aspect of the provenance of B9470047 LRXFE. It cannot though be the 1st production Tiger as WWA promoted and publicised it as.
yes.. the brackets for the expansion tank were in the wrong place and had to be moved and there was an issue with the gearbox.
They did not say that... they stated that it was chassis #47 very clearly... They said it was the 1st production body shell... which is indisputable. I fail to understand why you are all trying to tear this car down. NO ONE has EVER stated it was the 1st Tiger. What they have said from the beginning is that it is the very 1st Pressed Steel shell built.... which it is..
This is mostly the reason that the owner decided to sell the car... the politics of the club and the refusal to admit that this is the 1st Pressed Steel shell so frustrated him that he decided to swear of all things Tiger club. Personally, I completely understand, and I don't blame him at all for being disillusioned. I owned a MK2 tricarb 2 seat Healey. An early example that was sent to Gibraltar... only 214 of these were ever made and my car was the only one sent to Gibraltar... I got so much push back, even in the face of incontrovertible evidence that I finally told the Healey guys to ____ off, sold the car and built a 100M Healey with a 13B Rotary engine just to needle them.
There can be ZERO doubt of the body number as it was fastened by Pressed Steel BEFORE the shell was painted. I have pointed out, ad naseum, that Jensen played fast and loose with the sequence that cars were assembled. The FACTS are that the chassis plates were supplied to Jensen incompletely stamped. The last one or two characters of the chassis number were not stamped.. That's why they are a different font. The engine number wasn't stamped either as Rootes had absolutely no control over what engine Jensen installed... Also the color codes were stamped by Jensen, as Rootes had no idea what each specific color the car was painted.
You can obsess over which car is numerically first based on chassis number, or which is first based on body number... Jensen had the same control issues with the Big Healey....
The bottom line is... this car is JAL 001... Making it the very first Pressed Steel body sent to Jensen... That Jensen ______ up and set it aside is immaterial... The first 10 cars (or maybe half of them) have SAL body numbers which indicate an Alpine shell and these were all AF experimental cars. B9470011 was a factory comp car so really cannot be desiganated as the 1st as it was NOT available to the public. so.... The supposed 1st customer car would be #12.... I wonder what body number it has... one thing is for certain, It's not #1
spmdr
Who is to say that JAL 0001 was the first tag installed
on the first body down the assembly line?
More likely there was a box of 50 body tags
and the first one into the box was #1, at the
bottom, and the last one into the box was
#50 at the top.
And guess when they would get to #1 again?
DW
mr55s
When the bodies were assembled before paint, the JAL was the first identifier fastened to the car. It was also painted at this time in body colour. I think we can all accept that. Given that you have a box of tags, and your starting production, you start at ā€œ1ā€ , why else do you have numbering system, other than to keep things in order.
HRS121E
Easy does it..
Where am I 'tearing down' anything. My interest is to highlight false claims. Like the one in November 2023 about B9470001.
I have not denied B9470047 LRX has JAL 550001, the first PSC bodyshell; there is no 'refusal'. What I said was, Worldwide Auctions and others in their sales particulars and promotion added "Production No 1" and "The First Tiger"
Run this video to 1 min 31 sec and listen to the sales pitch "Production No 1 the first Tiger".https://listings.worldwideauctioneers.com/product/1964-sunbeam-tiger-mk-i-serial-1-roadster/#video-section
There is no need to address what you think Jensen did or didn't do unless it bears on this claim. But I would like to understand how it is known Jensen 'set it aside' as the reason for why it is the 47th Tiger built.
May I also ask what permits you to dismiss B9470011 / ROTA 1 as NOT the first production car... because it was assigned to the Competition Dept and not sold to the public.
If the 4 other rally Tigers - B9470012 to B9470015 - are to be equally dismissed then by that measure B9470016 is the first production Tiger.
To repeat I have not denied B9470047 LRXFE has the "very first Pressed Steel body" but that is all it may claim.
