Bolt-on Traction Masters
Steven43
I am installing bolt-on traction masters on my 65 M1, stock tiger. I have always used a D.W. torque-arms on my other tigers. But I am trying to go stock on this one. I have never seen a bolt-on traction master installed before.( in all my years of being around tigers , I never bothered to look to see if some one had bolt-on's) Is this even close to what it should look like ? And thanks to Mike M in the Valley for all the help with getting these part together.
Steven Alcala
Yup that's what the originals look like. They have the 3 bolt mounts....I don't know why they did that...but it's as per original.
If you want to install these on a Mk1a or Mk2 you have to install a thicker spacer to clear the rebound that was mounted on the top of the spring (forward end) or remove the rebound entirely.
IvaTiger
This set up is what I want for my mk1 because the PO had the weld on type which broke away from the chassis. I will shorten the bar and make up a clamp on type like pictured. Can you tell me if they are 7/16 NF bolts and how is the bar attached to the angle iron ( welded and threaded , or is it a rod that could slide in the angle iron ?)) Is that 5/16 or 3/8 angle iron ?
Also.. should note... Don't clamp them to hard at the front...there should be some allowance for them to slide a little as the spring arches.. otherwise the ride will be very stuff as they will start to limit more movement than they need to
Steven43
Maybe these photos can help some one who is trying to make a bolt-on out of an old weld-on. Also when welding Cast Iron to steel, use Cast-55 rod, pre heat - slow cool. (look on YouTube)
As a side note ( a mod so not for the factory correct) the original rubber bushings in the TM at the spring mounts bind.
You can use a modern sleeved poly bush and eliminate the issue...
Picture attached..
