the top one on the pump isn't connected to anythingThe top one in the photo or the top one on the pump (asking for a friend)![]()
it's not at the bottom of the trunk floor... pic attached.. The grommet in the picture is where the vent tube would come through. This hole is only found on Tigers. The hole in the trunk floor next to the battery is for the battery cap vent assy. the vent hose is only found on Mk1 and MK1a cars. The reason for the hose protruding into the trunk is to keep the vent clear of road debris. as the pump is located under the trap door it is totally exposed.So,..... if I am interpreting this correctly, the port on the end of the pump is not connected to anything. I would assume that it can be capped off. The port that is located more in the middle of the pump, is a vent. That vent could be routed with some clear tubing to the hole at the bottom of the spare tire well. Please confirm.
Thanks!
Got it. I am putting it in the MK2 position, so no vent hose to worry about.it's not at the bottom of the trunk floor... pic attached.. The grommet in the picture is where the vent tube would come through. This hole is only found on Tigers. The hole in the trunk floor next to the battery is for the battery cap vent assy. the vent hose is only found on Mk1 and MK1a cars. The reason for the hose protruding into the trunk is to keep the vent clear of road debris. as the pump is located under the trap door it is totally exposed.
MK2 cars don't have a vent tube as the pump is protected from the elements as it's inside of the trunk.
so if you're changing the location of the pump to the Mk2 spot, you don't need to worry about the vent hose.
I wondered what the tube was mine was not connected to anything , it was just hanging in the grommet with a few inches inches in the trunk and the other end almost touching the ground The original fuel pump was replaced with a German made fuel pump and probably did not have a use for the tube I have installed a SU pump and now I will attach that tube to it. Always learning and appreciate the feedbackit's not at the bottom of the trunk floor... pic attached.. The grommet in the picture is where the vent tube would come through. This hole is only found on Tigers. The hole in the trunk floor next to the battery is for the battery cap vent assy. the vent hose is only found on Mk1 and MK1a cars. The reason for the hose protruding into the trunk is to keep the vent clear of road debris. as the pump is located under the trap door it is totally exposed.
We have established where the tube enters the trunk but no confirmation of where on the pump it attaches. On the end where the points are or the middle of the pump , I am guessing the middle and allows the diaphragm to breathe ?So,..... if I am interpreting this correctly, the port on the end of the pump is not connected to anything. I would assume that it can be capped off. The port that is located more in the middle of the pump, is a vent. That vent could be routed with some clear tubing to the hole at the bottom of the spare tire well. Please confirm.
Thanks!
at the base of the electrical portion where it attaches to the alloy bodyWe have established where the tube enters the trunk but no confirmation of where on the pump it attaches. On the end where the points are or the middle of the pump , I am guessing the middle and allows the diaphragm to breathe ?
new pumps don't have the cap on the points end. looks like a Dunlop spare!Here's a pic of mine. Ground wire on middle connector. Vent to truck on middle fitting, clear hose. I do notice the vent on the end near positive wire has a plastic cap, whereas yours doesn't.
He was out of stock on the TM31F when I ordered the SU pump. I ordered this alternate kit instead of having no fittings.if you decide you want to run the fuel lines into the pump like a Mk2, the complete pair of fittings is available from Rick at sunbeam Specialties under part # TM31F
Can you give some details on the fuel shut off valve? Brand, input/output fitting sizes, where did you get it from?Small and simple. Easy fuel turnoff and filter/pump replacement. Carter pump and filter bought as a complete unit @ about $35 so complete backup unit can be brought along.
Thanks Ken!!Mine ends about 4-5 inches forward of that plate, about even with that brake line clip on the frame.
