In the back corners of the rear floor wells are the bolt-in mount points. They can be seen from under the car and should be "chased" with a 7/16" fine thread tap . You can also find the 3-point mount in the upper rear wheel wells.Possibly silly question as it might be obvious if I was looking at the car, but how are the lap belts mounted? There are currently none in our car. Are there existing mounting points, or is modification needed. ie: drilling holes?
