5 lug
I made my Tiger a 5 lug, so I could run the Shelby GT500KR rims. Plus the stock Tiger wheel studs looked awful skimpy to me for something with that much horsepower. Ditto brakes.
I used Dale's front suspension with the appropriate brakes and hubs (Dale was also able to lose an inch on each side in the track so the wheels don't stick out of the fenders), and in the back I used a set of un-drilled new hubs I got from Doug Jennings and had them drilled locally for the 5 x 4.5 pattern, with Dale's rear disc brake kit.
My "Plan B" for the back hubs would have been to turn down the stock hubs, press and dowel on a steel ring (and maybe braze as well), and drill that for the 5 bolt pattern.
My first attempt at the rear end was to buy a disc brake 8.8 Ford rear end out of a late model Explorer. I had that narrowed to the Tiger rear track and the spring perches and panhard rod mount installed, with a trac loc differential and 3.55 gears. I got it installed in the car, but the dimensions of the Explorer disc brake hardware is just too big for the Tiger. It quickly became obvious, that at normal ride height, if I hit a bump, some part of the brakes would be knocking on the inner fender or frame rail, and the springs were also in the way of the e-brake hardware. The calipers also rubbed on the inside of the Shelby rims. After a week or so of putzing and trying to re-clock the rear brakes, and grind away offending parts, I removed the 8.8 and put back in the Dana 44 (yet another trac-loc and 3.54 gears), with Doug's hubs, and Dale's rear disc brake kit. After talking to numerous people I decided that the Dana 44 is plenty strong enough for a Tiger, even one with a built stroker, mainly because of the Tiger's light weight - you'll get wheel spin before you'd break the differential. I'm not saying any Ford 8.8 won't work... but I'm pretty darn sure the Explorer isn't the one to start with. Fortunately I was able to have the 8.8 re-re configured to fit my 65 Mustang, where there's plenty of room for the brakes, so it wasn't a total loss.
After I did all that, I discovered that Dale sells Ford 9" rear ends in a custom housing, with disc brakes, that bolts right in a Tiger and he can put any bolt pattern you want on it. I would have gone that route instead of attempting the 8.8 if I'd have known about it first.
It's the Tiger law - every project gets put together and taken apart at least twice... some 5 or 6 times.
Bob K.
B9471705
