Track
The "official" rear track measurement I came up with when planning my 8.8 swap that didn't happen, was 48.5". Several knowledgeable people told me that was just an average number, that actual Tiger measurements varied considerably due to, among other factors, the axle/hub taper fit, and how tight the hubs were torqued. I was originally thinking of adding an inch on each side to make the rear track more like the front, but after test fitting my Shelby wheels in the body shell, I decided that they would fit real well with the stock rear track measurement of 48.5" (my car wheel mounting surface to wheel mounting surface is more like 48 13/16" with Doug Jenning's new hubs and Wilwood brake hats), and I should lose and inch on each side in the front so the tires wouldn't hang out of the fenders, which I accomplished with Dale's front suspension. Probably cost me a little in cornering but looks a lot better.
Bob K.
B9471705
Sunbeam Tiger 260 data
mm inches
Wheelbase 2184 86
Track (front) 1314 51.7
Track (rear) 1232 48.5
Length 3962 156
Width 1537 60.5
Height 1308 51.5
Ground clearance 114 4.5
length:wheelbase ratio 1.81
Kerb weight 1163 kg 2564 lb
Weight distribution 51.00 %
Bob K.
B9471705
mm inches
Wheelbase 2184 86
Length 3962 156
Width 1537 60.5
Height 1308 51.5
