Hi Michael, I have been told that using masking tape over the proposed hole and using a very sharp smallest drill you have can acheive the result you need. A very pointed punch lightly tapped also helps. I will still think about mine.
Steven,
Yes all of the above i am aware of.. the bit that worries me is that most of the holes wleded up.. not just filled.. i am worried about the bit catching and taking a chunk... i will get there... eventually!
I have been putting off the broken door hinges scew for quite a while. I googled various fixes, most saying go slowly, breaking the ezi-out is a another problem. So I decided on this sunny winter day (9c-24c) to attack the broken screw. I started by selecting a new drill bit that just fitted the hinge hole. I mounted the hinge with the remaining screws and started the drill. It took a few attempts but finally I had a starting point. Changed to a smaller bit and drilled a hole through the screw. At this time the experts said to see if you can either insert a thread remover or remove the old threads of the previous screw. Well, I increased the drill size by 64th inch checking with an old back plate. When my drill said it was less than the thread size and went thru, I retaped the hole and the hinge screw fits perfectly. great start to the day.
if you had to buy a body panel thru a dealer when there was still replacements available you got an alpine fender or door without the holes.
Been a long time, many things in the way. Today I called a nephew that owns three body shops and he is sending someone over to check my work and give an estimate for paint ready. Trembling that they don't think my replacing 3 fenders, 2 doors, 1 bonnet is crap. When its gone I will be worried however then I can strip the 5 bolt 289 and start on its rebuild with alloy heads, manifold, sump, billet dizi, 2 carbs, a 450 holley & 600 Edelbrok clone. Meanwhile the box will have wide band cogs fitted, the rear discs fitted, the front end rebuilt with a MG steering unit etc. Yippee (until I get the cheque from the body guys)
Well, its been some time, various happenings had stalled the project. Today I bit the bullit and have 2 body shops coming around to check my Tiger and decide the price for the final body work and paint.
Once I know that welding/fabrication has the overall dimensions correct, I will often step in and aggravate the troops by taking over the door fitting issues. Personally, I like to run a bit more gap at the top rear knowing that it will tend to close over time. Many times we end up removing the hinges on the doors and deepen the hinge's seating area just a tad in order to gain some shim adjustment spacing. And YES, it is very important to tighten ALL the hinge screws EVERY TIME the door is mounted. Snugging only a few WILL NOT give you an accurate position.
