I have run a DW TA for years in open track events. No negative changes in weight transfer. What is push? under steer is easy to cancel lifting throttle with or without TA.
Regarding "burnouts" DW did not intend the torque arm for drag racing. Autocross is where it shines because it relieves the leaf springs from being the only counter to pinion rise under power and the opposite on decelleration/braking. Makes everything easier for driving hard!
That said? If you have under 300hp or never drive aggressively you may not need one.
Believe what you want. I have a little experience with TA's and not only took TToD at the SUNI autocross (in a sub 300hp car on 195 street tires that was finished two days before leaving) but also just picked up the SCCA Solo National Championship jacket in DS at Lincoln, NE this week (yes, I needed to toot my own horn LOL). I also have had success road racing, prior to focusing on autocross
You guys have to stop drinking from the same Kool Aid :lol:
Also, as I said, I'm talking about stock front suspension. If enough work is done on the front, the torque arm can be additive. But, given the "set ups" being described and typically found on Tigers, that's not going to be the case.
