KenF
I figure since I bought the Tiger from my neighbor and it now sits in my shop (as told here), I'd start a new thread on its progress. I know Mustangs well, but not Tigers, so I welcome the guidance. My goal over the next month or two is this:
So it begins.
Yeah, ain't going to use this toilet paper oil filter! Can't believe people used these things. Today's paper probably wouldn't last a minute. I want to remove it anyway so I can see the engine assembly date.
The American Racings mags have no cast markings or stampings on the inside. Surprisingly no curb rash on them. I don't know what I'm going to do with these, really not too wise to ride them hard, if all all.
And what is this painted numbered tag on the cowl? Says JAL 560992.
I also want to check the numbers on the trans and diff. I know the block number and casting date locations, but not the others. Any hints what to look for? Or any other advice for a car that's sat for a long time.
Thanks, Ken
- Join CAT (Done!).
- Strategy for now is to leave as much as possible unrestored, and replace only as needed to safely and reliably drive.
- Get car onto jack stands. I need to figure out the best way to jack the front without doing damage (Done!).
- Remove wheels and have tires dismounted. Get wheels checked to see if they're usable.
- Rebuild brake system.
- Rebuild clutch master/slave system.
- Replace fuel tank rubber parts.
- Might drop oil pan, who knows what sludgy stuff is laying down there.
- Change all coolant related hoses.
- Hope the radiator and heater core don't leak.
- Start rounding up parts that are missing.
- Figure out what to do for wheels/tires.
- Once running, get it TAC'd. Maybe I should request this now.
So it begins.
Thanks, Ken
