Looking for Repro Cobra Rims
cleistertiger
So Cliff convinced me to go with 15" rims instead of 16".....I love these rims but they don't come in 4x108 bolt pattern....I've seen them on Tigers and not the PS Engineering wheels that cost a fortune....anyone have a line on where I can get this style wheel in the right bolt pattern 15"?
https://legendarywheel.com/product/lw90/
Chris
lw90
Maliburevue
15" Cobra Wheels
You mean like these? 10 years ago I restored a Tiger for a friend and he put on these wheels. He got PS Engineering to tweek his front wheels to reduce the front track width.
Gary
cleistertiger
PS Wheels
They are beautiful but they cost $500 a piece.....I'm looking for a more economical solution. A company called legendary wheels has them but they don't have a Tiger bolt pattern and are $130....anyone else out there seen any other vendors?
Maliburevue
Machining
A machinist friend of mine at work had a milling machine at home and shaved off 1/4 " from the backside of my aluminum wheels with no problem. They run true and straight.
I'm sure a competent machine shop could slot those mounting holes 1/8" to make the 4.25" bolt pattern.
Have you asked Legendary if they would offer a 4.25 pattern?
cleistertiger
No Luck
Yes...asked them...they said they were going to run a batch with
Tiger bolt pattern if they got a good response to the wheels....said response has been poor and they are going to discontinue....still looking
1966 TGR
These are really nice. Don't give up. I had a set of x 4-1/2 Ansen slot mags machined to accept 4 x 4-1/4. WHeels are either hub-centric or stud-centric. If the wheels are hub-centric, meaning that the axle hub is a precise fit into the center hole of the wheel, they will be concentric. If there is a mismatch between the O.D. of the TIger hub and the I.D. of the wheel center hole, www.justforwheels.com will make a custom set of adapter rings, for around $30. I found that the rear wheels were not as critical and that the elongated slots aligned the wheel just fine, no vibration. It looks like these wheels use shank type lug nuts which would make this feasible. Stud-centric wheels depend on conical lug nuts to center the wheel between the studs. If these wheels are stud-centric, I think you are out of luck.
1966 TGR
adapter ring photo
adapter ring photo attached, I think
AshUK
You could always convert your hubs to 5 lug fitment but I don't think those wheels will fit inside the front fenders due to the offset. You only have roughly 2.5" from the bolt face to the front fender edge so ideally you would go for a 6" wide rim with -1" (24mm) offset.
