tigresunbeam
Forum Member
Is there a difference between the MKII speedometer , and the MKIA speedometer outside of the front Facia.
Is the internal the same .
Wonder if that could be 3d printedWhat’s an unobtanium 15 tooth gear worth these days ?? Just askin’…
I don’t see why it can’t be 3D printedWonder if that could be 3d printed
I'm naive and inexperienced with 3-D tech: Would such a critter be durable enough?I don’t see why it can’t be 3D printed
56000 milesThanks for the picture maybe an edit is in order to scratch out the phone number. The ones I have do not look that nice.
like theseSpeaking of : Has anyone found a source for the MK1 LH driven gear ?
Yup: I have a good collection of the drive gears like the green, but, the driven gears are counting short of the projects.
There would be a lot of time involved in getting the correct compound and geometry to make it feasible
Nylon is available just not sure if all nylon is the same. Not a material engineer but will look around. The YouTube video above shows nylon and polycarbonate failing under tension. This application wouldn't likely be under the same resistance but would have to withstand heat, oil and repetition.The original gears are likely nylon. I don't know if that is available for 3D printing.
