I would agree it's question whether a printed part will hold up in this application. From my experience, which is not extensive, printed parts can be very accurate but do not have the same integrity as a part that was molded under tons or pressure. Printing is great for things like housings and non working parts but that is not the case here. Not the greatest load on a speedo gear but some nonetheless.Nylon is available just not sure if all nylon is the same. Not a material engineer but will look around. The YouTube video above shows nylon and polycarbonate failing under tension. This application wouldn't likely be under the same resistance but would have to withstand heat, oil and repetition.
Some differing types of resin are below. I think one of the more time-consuming parts would be creating the 3D scan to be used as the model for printing the gear.
https://taulman3d.com/index.html
Further Googling shows that there are 3D Print Services to be had. Perhaps something that can be contracted out instead of buying and experimenting.
I'm not saying it won't work but there are questions.
